Введение
If you're noticing that Alcatel Fierce 4's Front camera is not functioning well and has black spots or slow but you are not ready to upgrade your phone and you like it. It’s the time to replace the camera. Follow this guide from start to finish!
Выберете то, что вам нужно
Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
Use a plastic opening tool to disconnect all of the cables on the motherboard.
Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
Use a plastic opening tool to pry up the camera connector from the motherboard.
Remove the camera.
