Введение
If you're noticing that Alcatel Fierce 4's speaker is getting bad and low and you can’t hear well but you are not ready to upgrade your phone and you like it. It’s the time to replace the speaker. Follow this guide from start to finish!
Выберете то, что вам нужно
Pry off the mid-frame using a plastic opening tool, working your way around the perimeter.
Use a plastic opening tool to disconnect all of the cables on the motherboard.
Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
Еще один человек закончил это руководство.
