Введение
Use this guide to replace the headphone jack. This guide requires soldering.
For more information on how to solder and desolder connections, please visit this guide.
Инструменты
Запчасти
Детали не указаны.
Pry back cover open with a medal spudger, or your fingernail, in the divot at the bottom left corner of the phone.
Lift open case by the corner nearest the divot and remove it from the phone.
Use the Plastic Opening tools to gently dislodge the two connection on the top and bottom right of the phone from the inside of the phone.
Use a pair of tweezers to pull the black ribbon connector from its port.
Use a metal Spudger to gentle remove the speaker that glued at the bottom left of the phone.
Using a plastic opening tool, begin to gently pry the motherboard, away from the display assembly.
The motherboard will freely remove.
Flip the motherboard upside-down and desolder the pin connection of headphone jack to the motherboard.
Once pins desolder, pull the headphone jack out.
