Выберете то, что вам нужно
Locate the small indent on the lower left corner.
Use your fingers or a small plastic opening tool to lift the back cover off.
Locate the indent between the battery and your phone.
Use your finger or a small plastic opening tool to lift the battery free.
Using the Phillips screw driver, remove the 9 screws from the phone.
Using your prying tool, place it between the screen and the back cover and pry it open.
Remove the volume and power button using your prying tool.
Go underneath the bronze plate with your prying tool and carefully pry it off.
