Alcatel One Touch Fierce Battery Replacement
Выберете то, что вам нужно
  1. Alcatel One Touch Fierce Battery Replacement, Rear Case: шаг 1, изображение 1 из 2 Alcatel One Touch Fierce Battery Replacement, Rear Case: шаг 1, изображение 2 из 2
    • Pry with a plastic opening tool, or your fingernail, in the divot at the bottom left corner of the phone.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Alcatel One Touch Fierce Battery Replacement, Midframe: шаг 2, изображение 1 из 3 Alcatel One Touch Fierce Battery Replacement, Midframe: шаг 2, изображение 2 из 3 Alcatel One Touch Fierce Battery Replacement, Midframe: шаг 2, изображение 3 из 3
    • Remove the 11 Phillips #000 screws.
    • The midframe should lift free.
  3. Alcatel One Touch Fierce Battery Replacement, Battery: шаг 3, изображение 1 из 2 Alcatel One Touch Fierce Battery Replacement, Battery: шаг 3, изображение 2 из 2
    • Use the tip of a spudger to pull back the yellow tape covering the battery connector.
    • Use a pair of tweezers to pull the battery connector from its port.
    • Be careful not to tear the battery from its connection.
Заключение
23 участников успешно повторили данное руководство.
Jonathan Ruiz
Участник с: 12/13/11
1 322 Репутация
Автор 2 руководств
6 Комментариев
Hello.. please suggest how to remove battery of one touch FLASH.
It is non removable battery.. Since my mobile is unable to reboot I need to remove back cover to make it work
Kapil Chaudhari - Ответить
remove sd and sim cards with power off…same as fierce 4/pop 4 all Phillips 000 screws come out then carefully unsnap inner back case half from main case starting on opposite side of power button.with each snap undone, carefully pry case half’s apart using plastic tool or credit card. once apart, unfasten battery connector. power up phone before re assembly.once it works power off and reverse instructions to assemble.
john vanlandingham - Ответить
If the battery is so easy to remove, why is it called “non-removable”?
fbanks47 - Ответить
how do you reboot after battery replacement
Alan Duncan - Ответить
How do I transfer google files from my alcotel phone to my computer
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 10
За последние 30 дней: 38
За всё время: 74,586
