Введение
This guide will walk you through the steps on changing your phones SIM card with guided pictures to help at every stage
Выберете то, что вам нужно
Locate the small indent on the lower left corner.
Use your fingers or a small plastic opening tool to lift the back cover off.
Locate the indent between the battery and your phone.
Use your finger or a small plastic opening tool to lift the battery free.
Locate the SIM card slot at the top left of the phone.
If an SIM card is not present, you can skip to step 4
The SIM card will have an indent at the top, use this to carefully pull the card from the slot.
Grab the new SIM card making sure not to touch the metallic area.
With the metallic patch facing down, insert the card into the slot.
Еще один человек закончил это руководство.
