Выберете то, что вам нужно
Locate the small indent on the lower left corner.
Use your fingers or a small plastic opening tool to lift the back cover off.
Locate the indent between the battery and your phone.
Use your finger or a small plastic opening tool to lift the battery free.
Remove back plate from phone.
Locate indent on corner of phone
Use pry tool to take off back of phone.
Find a very slim object to slide in between glass and phone.
Pry it off little by little until you are able to take it off.
After screen is off apply new screen
Make sure cable is in correct place after putting glass back on.
Test to make sure it works.
