Alcatel OneTouch Pop Icon Motherboard Replacement
Выберете то, что вам нужно
  1. Alcatel OneTouch Pop Icon Motherboard Replacement, Battery: шаг 1, изображение 1 из 1
    • Shut down the device
    • Flip the phone so that the screen is facing the surface you are working on
    • Aggressive prying may result in damaging the back panel or the internal contents of the phone.
    • Use the plastic opening tool to gently pry off the back panel. There is a small notch in the bottom left corner of the phone that you can use for increased leverage.
  2. Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 2, изображение 1 из 2 Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 2, изображение 2 из 2
    • Use your thumbnail to lift the battery from the phone.
  3. Alcatel OneTouch Pop Icon Motherboard Replacement, Interior Back Panel: шаг 3, изображение 1 из 1
    • Using the J000 Phillips screwdriver, remove the twelve silver 3mm screws.
    • Using the J000 Phillips screwdriver, remove the one green 3mm screw.
  4. Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 4, изображение 1 из 1
    • With the screen facing you and the front facing camera to your right, insert the plastic opening tool between the screen and the interior back panel and gently pry it off.
    • Make sure all of the clips come undone when you pry the seam loose.
  5. Alcatel OneTouch Pop Icon Motherboard Replacement, Control Buttons: шаг 5, изображение 1 из 1
    • Lift the latch and gently remove the ribbon from the latch.
  6. Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 6, изображение 1 из 2 Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 6, изображение 2 из 2
    • Use the metal spudger to gently pry the control buttons from the case.
    • The control buttons are glued to the case and are on a computer ribbon. When removing them it is best to move between them so as to avoid damaging them.
    • Make sure to use a plastic opening tool or nylon spudger before attempting to use a metal spudger. Metal spudgers can potentially damage your device.
  7. Alcatel OneTouch Pop Icon Motherboard Replacement, Motherboard: шаг 7, изображение 1 из 3 Alcatel OneTouch Pop Icon Motherboard Replacement, Motherboard: шаг 7, изображение 2 из 3 Alcatel OneTouch Pop Icon Motherboard Replacement, Motherboard: шаг 7, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Купить
    • Using tweezers, carefully detach the antenna from the motherboard.
  8. Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 8, изображение 1 из 3 Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 8, изображение 2 из 3 Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 8, изображение 3 из 3
    • Remove the tape on top of the ribbon.
    • Lift the black latch to release the ribbon.
    • Remove the ribbon from the latch.
  9. Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 9, изображение 1 из 1
    • Lift the tab from the casing.
  10. Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 10, изображение 1 из 3 Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 10, изображение 2 из 3 Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 10, изображение 3 из 3
    • Use the tweezers to remove tape the from the top of the latch. Still using the tweezers, lift the black latch to release the ribbon.
  11. Alcatel OneTouch Pop Icon Motherboard Replacement: шаг 11, изображение 1 из 1
    • Remove the motherboard from the casing.
Заключение
2 участников успешно повторили данное руководство.
John Halsey
Участник с: 04/01/16
1 000 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team 2-2, Andersen Spring 2016 Участник Eastern Washington University, Team 2-2, Andersen Spring 2016
EWU-ANDERSEN-S16S2G2
5 членов
Автор 14 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 11
За всё время: 1,966
