Введение
The Motherboard is the most complicated part of the phone to remove because almost all of the phones components are connected to it. This guide will show you how to properly remove the Alcatel Pop 4 Plus Motherboard in a few simple steps. Be gentle with removing the connectors and make sure you line them up properly when snapping them back together.
Выберете то, что вам нужно
Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
Use the flat end of the spudger disconnect the battery from the motherboard.
Use the flat end of the spudger tool to pry out the battery.
Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
Slide the ribbon cable out of the socket.
2 участников успешно повторили данное руководство.
Один комментарий
Hi
I got my Alcatel Pop 4+ checked and it's Power IC was faulty. How can I replace it
I'm looking for the specific IC used in it if I can get any help regarding it.
