Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the back cover by sliding your fingernail in the grove around the edge of the phone and prying it off.
Remove seventeen 3mm Phillips #000 screws from the mid-frame.
Use the flat end of the spudger, or your fingernail, to pry off the mid-frame.
Use the flat end of the spudger disconnect the battery from the motherboard.
Use the flat end of the spudger tool to pry out the battery.
Use a spudger to flip up the retaining flap on the USB ribbon cable ZIF socket.
Slide the ribbon cable out of the socket.
Use the flat end of a spudger to disconnect the ribbon cable.
Using the flat end of the spudger to disconnect the ribbon cable.
Using the flat end of the spudger, disconnect the camera from the motherboard.
Use the flat end of the spudger to pry off the motherboard.
2 участников успешно повторили данное руководство.
Один комментарий
Hi
I got my Alcatel Pop 4+ checked and it's Power IC was faulty. How can I replace it
I'm looking for the specific IC used in it if I can get any help regarding it.
