Введение
Caution: Handling of Sharp Objects
Please use caution when handling tweezers and keep out of reach of children.
If you notice that your phone has a delay in locking or turning the volume up and down, it is recommended that you change your Power/Volume button rocker.
Выберете то, что вам нужно
Begin by removing the back of the phone. Press your nail or a thin object in the bottom right-hand corner of the phone and gently press to release the back of the phone from the front.
Once removed completely, use the back portion to disassemble the Power/Volume Button Rocker.
Remove the middle insert of the elastic on the Power/Volume button rocker with tweezers.
Once removed, place new rocker in same elastic slots. Follow instructions backwards to reassemble.
