Введение
In this guide, we will be showing you how to remove and replace the Solid-State Drive.
Инструменты
Запчасти
Детали не указаны.
After turning the computer off, close the display and turn the computer over.
After the computer base (#1) is facing up, use a Philips screwdriver to remove the two captive screws (#2) which hold the base panel (#3) down.
Then, use a spudger (#4) to lift up the panel. You can also use your fingernail to lift it as well.
After the front has been lifted up a bit, the non-screw side of the panel will need to be slid forward a little to finish lifting out the base panel from the computer.
Disconnect the battery cable from the system board by pulling up on the battery connector (#1).
Turn the computer back over and open the display to the point where you can press the power button.
Press and hold the power button for 4 seconds to ground the system board so that you can safely remove components such as the RAM.
Remove the screw that secures the solid-state drive to the computer base.
Slide and remove the solid-state drive from the solid-state drive slot.
Slide the solid-state drive into the solid-state drive slot.
Align the screw hole on the solid-state drive with the screw hole on the computer base.
Replace the screw that secures the solid-state drive to the computer base.
To reassemble your device, screw the base panel on again.
Еще один человек закончил это руководство.
