Введение
This guide will show you how to replace your Hard Drive.
Выберете то, что вам нужно
Make sure the laptop is unplugged from any power source.
Put the laptop facing down on a hard surface.
Unscrew the two 6mm screws on the bottom side of the laptop.
Lift up the back cover and slide towards you.
Now that the hard drive casing is off, carefully unplug the hard drive from the laptop
Your hard drive has now been successfully removed from your device
