Alienware 17 R2 Wireless Card Replacement
Выберете то, что вам нужно
  1. Alienware 17 R2 Wireless Card Replacement, Removing the Screw: шаг 1, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screw that secures the wireless-card bracket and the wireless card to the system board.
  2. Alienware 17 R2 Wireless Card Replacement, Lifting the Card Bracket: шаг 2, изображение 1 из 1
    • Lift the wireless-card bracket off the wireless card.
  3. Alienware 17 R2 Wireless Card Replacement, Disconnecting Antenna Cables: шаг 3, изображение 1 из 1
    • Disconnect the antenna cables from the wireless card.
  4. Alienware 17 R2 Wireless Card Replacement, Removing the Wireless Card: шаг 4, изображение 1 из 1
    • Lift and slide the wireless card from the wireless-card slot.
    • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
    • Align the notch on the wireless card with the tab on the wireless-card slot.
  5. Alienware 17 R2 Wireless Card Replacement, Sliding the Wireless Card: шаг 6, изображение 1 из 1
    • Slide the wireless card at an angle into the wireless-card slot.
  6. Alienware 17 R2 Wireless Card Replacement, Connecting Cables to the Wireless Card: шаг 7, изображение 1 из 1
    • Connect the antenna cables to the wireless-card.
    • The following is the antenna-cable color color scheme for the wireless card: Main (white triangle) = White Auxiliary (black triangle) = Black
  7. Alienware 17 R2 Wireless Card Replacement, Aligining the Screw Holes: шаг 8, изображение 1 из 1
    • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card.
  8. Alienware 17 R2 Wireless Card Replacement, Replacing the Screw: шаг 9, изображение 1 из 1
    • Replace the screw that secures the wireless-card bracket and the wireless card to the system board.
Заключение
Terrence15
Участник с: 12/18/17
78 592 Репутация
Автор 441 руководств
Команда
Informative Technologies Inc. Участник Informative Technologies Inc.
Community
38 членов
Автор 1 982 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 22
За всё время: 600
