Alienware AW610M Scroll Wheel Replacement
Выберете то, что вам нужно
  1. Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: шаг 1, изображение 1 из 3 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: шаг 1, изображение 2 из 3 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: шаг 1, изображение 3 из 3
    • Turn your mouse over with the scroll wheel facing down.
    • Use a precision blade (I used size 12) to loosen the adhesive surrounding any stickers on the back of the mouse.
    • Be cautious with the blade and move in slow, controlled motions as to avoid any injury.
  2. Alienware AW610M Scroll Wheel Replacement: шаг 2, изображение 1 из 2 Alienware AW610M Scroll Wheel Replacement: шаг 2, изображение 2 из 2
    • Turn your blowdryer on a low heat setting.
    • Precisely aim the heat on the adhesive sections of the mouse for 5-10 second intervals.
    • Turn off your blowdryer, unplug the device, and set it aside to cool down.
    • Carefully peel off the stickers, and set aside as well.
  3. Alienware AW610M Scroll Wheel Replacement: шаг 3, изображение 1 из 3 Alienware AW610M Scroll Wheel Replacement: шаг 3, изображение 2 из 3 Alienware AW610M Scroll Wheel Replacement: шаг 3, изображение 3 из 3
    • Use your Phillips #00 screwdriver to remove four 3.1 screws from the mouse.
  4. Alienware AW610M Scroll Wheel Replacement: шаг 4, изображение 1 из 1
    • Gently prop open the back side of the mouse; be careful as to not break any plastic while doing so.
    • Don't pull apart the mouse backing too far, as connections still hold the two pieces together.
  5. Alienware AW610M Scroll Wheel Replacement: шаг 5, изображение 1 из 3 Alienware AW610M Scroll Wheel Replacement: шаг 5, изображение 2 из 3 Alienware AW610M Scroll Wheel Replacement: шаг 5, изображение 3 из 3
    • Disconnect any wire connections away from the mouse's circuit board.
    • Be careful disconnecting the ribbon cable labeled AWM 20706, as you might not be able to reconnect it without damaging the pins, later on.
    • Locate the scroll wheel placed in the gap of the mouse's backing.
    • My scroll wheel was crooked, most likely causing my issue.
    • Gently lift the scroll wheel mechanism out of the mouse's backing.
  6. Alienware AW610M Scroll Wheel Replacement: шаг 6, изображение 1 из 3 Alienware AW610M Scroll Wheel Replacement: шаг 6, изображение 2 из 3 Alienware AW610M Scroll Wheel Replacement: шаг 6, изображение 3 из 3
    • Disconnect the scroll wheel sensor from the mouse backing.
    • Remove the old wheel from the plastic casing, and set it aside.
    • Use a dry cotton swab to wipe off dust or debris in the wheel's plastic casing.
  7. Alienware AW610M Scroll Wheel Replacement: шаг 7, изображение 1 из 3 Alienware AW610M Scroll Wheel Replacement: шаг 7, изображение 2 из 3 Alienware AW610M Scroll Wheel Replacement: шаг 7, изображение 3 из 3
    • Dip a cotton swab into hydrogen-peroxide.
    • Make sure to wear gloves or wash your hands after handling hydrogen peroxide. Be cautious to avoid touching your face in this step.
    • Use a wet cotton swab to clean the mouse backing. Don't hesitate to swipe behind different pieces of plastic as well.
    • Avoid using cotton swabs on the circuit board of the mouse, or any wires in the mouse.
Заключение
2 человек успешно провели ремонт по этому руководству.
Rana Ashour
Участник с: 04/04/23
193 Репутация
1 руководство автора
Команду
CSU Los Angeles, Team 2-71, Briggs Spring 2023 Участник CSU Los Angeles, Team 2-71, Briggs Spring 2023
CSULA-BRIGGS-S23S2G71
1 член
Автор 3 руководств
Один комментарий
Note: the tan part connected to the ribbon cable IS A RECEPTACLE, THE RIBBON CABLE ITSELF IS THE PART THAT PULLS OUT. I accidentally pulled off my connector, lost a connector pin when attempting to put it back on, mouse still seems to work though.
Nathan - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 20
За последние 7 дней: 91
За последние 30 дней: 424
За всё время: 8,222
