Введение
Перейти к шагу 1 ↓This guide will show you how to safely access and replace the hard drive for the Alienware M14xR2 laptop. Before replacing the hard drive you will need to remove the battery and the CD drive.
Выберете то, что Вам нужно
Ремонтный комплект
Этот комплект содержит все детали и инструменты, используемые в инструкции.
Запчасти
Инструменты
Turn the computer off.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
Slide the back cover towards you and then lift upwards to remove.
Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
Pull up on the white connector to disconnect it from the laptop.
The battery is now free to remove from the laptop and can be set aside.
Unscrew the four 6.35 mm size 1 screws.
Pull up on the end of the orange tab to detach it from the white connector.
Lift the optical drive up and out of the laptop and set it aside.
Loosen the three 6.35 mm size 1 screws to release the hard drive from the rest of the laptop.
Pull the connector that is attached to the cable at the end of the hard drive out and away from the hard drive to detach it.
Set aside the now disconnected hard drive.
5 человек успешно провели ремонт по этому руководству.
