Alienware M14xR2 Status-Light Board Replacement
Выберете то, что вам нужно
  1. Alienware M14xR2 Status-Light Board Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn the computer off.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the charging cable could result in electric shock and serious injury.
    • Flip the computer upside down.
  2. Alienware M14xR2 Status-Light Board Replacement: шаг 2, изображение 1 из 3 Alienware M14xR2 Status-Light Board Replacement: шаг 2, изображение 2 из 3 Alienware M14xR2 Status-Light Board Replacement: шаг 2, изображение 3 из 3
    • Loosen the two 6.35 mm size 1 Phillips screws on the back cover.
    • The two screws are spring loaded and will not separate from the cover.
    • Slide the back cover towards you and then lift upwards to remove.
  3. Alienware M14xR2 Status-Light Board Replacement: шаг 3, изображение 1 из 1
    • Loosen the two 6.35 mm size 1 Philips screws attaching the battery to the laptop.
    • The two screws are clipped into the battery and will not detach.
  4. Alienware M14xR2 Status-Light Board Replacement: шаг 4, изображение 1 из 3 Alienware M14xR2 Status-Light Board Replacement: шаг 4, изображение 2 из 3 Alienware M14xR2 Status-Light Board Replacement: шаг 4, изображение 3 из 3
    • Pull up on the black tab on the battery to reveal the connection between the battery and laptop.
    • Pull up on the white connector to disconnect it from the laptop.
    • The battery is now free to remove from the laptop and can be set aside.
  5. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: шаг 5, изображение 1 из 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before You Begin.
    • Turn the palm-rest assembly over.
  6. Alienware M14xR2 Status-Light Board Replacement, Remove the Cable: шаг 6, изображение 1 из 1
    • Note the routing of status-light board cable and remove the cable from the routing guides.
    • NOTE: If the status-light board cable is under the speakers cable, remove the speakers cable first and then remove the status-light board cable.
  7. Alienware M14xR2 Status-Light Board Replacement, Turn the Palm-Rest Assembly Over: шаг 7, изображение 1 из 1
  8. Alienware M14xR2 Status-Light Board Replacement, Remove the Screw: шаг 8, изображение 1 из 1
    • Remove the screw that secures the status-light board to the palm-rest assembly.
  9. Alienware M14xR2 Status-Light Board Replacement, Lifting the Status-Light Board: шаг 9, изображение 1 из 1
    • Carefully lift the status-light board and release its cable from the slot on the palm-rest assembly.
  10. Alienware M14xR2 Status-Light Board Replacement, Slide the Status-Light Board Cable: шаг 10, изображение 1 из 1
    • Slide the NEW status-light board cable through the slot in the palm-rest assembly.
  11. Alienware M14xR2 Status-Light Board Replacement, Align the Slot: шаг 11, изображение 1 из 1
    • Align the slot on the status-light board with the alignment post on the palm-rest assembly.
  12. Alienware M14xR2 Status-Light Board Replacement, Replace the Screw: шаг 12, изображение 1 из 1
    • Replace the screw that secures the status-light board to the palm-rest assembly.
  13. Alienware M14xR2 Status-Light Board Replacement, Turning the Palm-Rest Assembly Over: шаг 13, изображение 1 из 1
  14. Alienware M14xR2 Status-Light Board Replacement, Routing the Status-Light Board Cable: шаг 14, изображение 1 из 1
    • Route the status-light board cable through the routing guides on the palm-rest assembly.
Заключение
Terrence15
Участник с: 12/18/17
79 121 Репутация
Автор 441 руководств
Команда
RampUP America, Inc. Участник RampUP America, Inc.
Community
42 членов
Автор 1 986 руководств
Один комментарий
Völliges Durcheinander und unvollständig
Robert Fleischhauer - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 15
За всё время: 674
