Введение
Use this guide for help on removing the compartment door. This is necessary for other replacement guides such as the GPU and the hard drive.
Запчасти
Никакие детали не требуются.
  1. Remove the battery by sliding the latch to the left and pulling the battery up. Remove the battery by sliding the latch to the left and pulling the battery up. Remove the battery by sliding the latch to the left and pulling the battery up.
    • Remove the battery by sliding the latch to the left and pulling the battery up.
  2. Free shipping on all orders over 100 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
  3. Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip. Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
    • Remove the two 4-mm screws that hold the compartment door to the rest of the computer using a PH#0 screwdriver tip.
  4. Slide the compartment door towards the front of the computer and lift. Slide the compartment door towards the front of the computer and lift. Slide the compartment door towards the front of the computer and lift.
    • Slide the compartment door towards the front of the computer and lift.
Заключение
Jake Alexander
Участник с: 22.01.2018
85 Репутация
1 Guide authored
Команда
Cal Poly, Team S11-G3, Banghart Winter 2018 Member of Cal Poly, Team S11-G3, Banghart Winter 2018
CPSU-BANGHART-W18S11G3
5 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 1
За 7 дней: 4
За 30 дней: 6
За всё время: 99
