Введение
Upgrade your hard drive for more storage space.
Инструменты
Запчасти
First, take off the battery by moving the latch to the left and pulling it up.
Then unscrew the two Phillips screws.
Pull the cover down, then up, revealing the internals
Unscrew the four screws indicated
Pull on the tab that says "Pull" and remove the Hard Drive
With even pressure on both sides, take off the SATA converter and then connect it to the drive you would like to replace it with.
7 участников успешно повторили данное руководство.
