Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Upgrade your RAM for an instant increase in speed.
The M15x uses DDR3 1333MHz memory.
Выберете то, что вам нужно
First, take off the battery by moving the latch to the left and pulling it up.
Then unscrew the two Phillips screws.
Pull the cover down, then up, revealing the internals
Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
After the RAM chip has popped up, pull it straight out of its socket.
7 участников успешно повторили данное руководство.
Один комментарий
I saw somewhere that it actually takes DDR2 ram not DDR3....
