Введение
The RAM is a vital component in the Alienware M17-R1. As larger programs are being released, they will require more memory, meaning that the RAM may need to be upgraded.
Выберете то, что вам нужно
Remove the nine 3 mm screws that secure the cover using a Phillips #1 screwdriver.
After locating the RAM, gently pull the two metal clips outward and lift the RAM card out of its socket.
To insert the new RAM, place it on top of the socket and carefully apply downward pressure until it snaps into place.
