Введение
If your battery can't keep a charge or drains quickly, use this guide to remove and replace your battery.
Выберете то, что вам нужно
Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
Slide cover forward then carefully lift up.
Carefully use the Plastic Opening Tool to unplug the battery.
Lift the battery up and out to remove.
3 человек успешно провели ремонт по этому руководству.
