Введение
If your hard drive is failing or needs updating, use this guide to remove and replace your hard drive.
Выберете то, что вам нужно
Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
Slide cover forward then carefully lift up.
Carefully use the Plastic Opening Tool to unplug the battery.
Lift the battery up and out to remove.
With the laptop flipped over, cover removed, and battery removed; continue by locating your hard drive(s).
Remove the eight 3.5 mm Phillips #0 screws.
Remove the hard drive(s), using the Plastic Opening Tool by lifting on the edges and pulling the hard drive up and out.
Еще один человек закончил это руководство.
