Введение
Are the keys not registering when you type? Consider using this guide to replace the keyboard in your laptop.
Выберете то, что вам нужно
Press down on the battery latch and slide it to the left.
Lift the battery out once it pops out.
Remove the two 2mm Phillips #0 screws from the recesses on the left and right side of the processor fan.
Turn the laptop top side up and fully open the display.
Pry the center control panel up from its left and right edges with the Spudger.
Lift the center control panel from the laptop.
Tilt the center control panel away from the display carefully.
Lift the latch open to remove the cable connecting from the laptop to the center control panel.
Slide and lift the keyboard towards the display to unhook it from the laptop.
Tilt the keyboard away from the display carefully.
Flip open the two latches that connect the wide keyboard cable and thin light cable to the laptop.
Lift the keyboard off the laptop and set aside.
Еще один человек закончил это руководство.
