Введение
This guide will show you how to replace the hard drive for the Alienware P18G M14X R1. To replace the hard drive you will need to remove the battery and the Optical drive.
Выберете то, что вам нужно
Loosen the top left and top right 6.5mm PH1 screws that hold down the back cover.
Using PH1 screwdriver loosen the two screws on the right of the battery.
Unscrew the four 6.35mm screws using the PH1, that hold down the optical drive.
Using the plastic opening tool unclip the white connector holding down the orange cable.
Using the tab on the optical drive, lift the optical drive out of the computer and set it aside.
Loosen the three 6.35 mm screws using the PH1 screw driver, to release the hard drive.
6 участников успешно повторили данное руководство.
