AlphaSmart Pro Lithium Coin Battery Replacement
Выберете то, что вам нужно
  1. AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: шаг 1, изображение 1 из 3 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: шаг 1, изображение 2 из 3 AlphaSmart Pro Lithium Coin Battery Replacement, Separating Panels: шаг 1, изображение 3 из 3
    • Removing the lithium coin battery will erase existing files. Make sure all important files have been safely transferred to another device before attempting to remove the lithium coin battery.
    • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
    • Remove the eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
    • Carefully separate the front panel from the back panel.
    • Notice that the front and back panels are still connected by a ribbon cable.
  2. AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: шаг 2, изображение 1 из 2 AlphaSmart Pro Lithium Coin Battery Replacement, Detaching Ribbon Cable: шаг 2, изображение 2 из 2
    • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
    • Gently pull up on the connector to completely remove the connector from the socket.
  3. AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: шаг 3, изображение 1 из 2 AlphaSmart Pro Lithium Coin Battery Replacement, Locate Lithium Coin Battery: шаг 3, изображение 2 из 2
    • With the front panel removed, locate the lithium coin battery at the top left corner of the motherboard.
  4. AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: шаг 4, изображение 1 из 2 AlphaSmart Pro Lithium Coin Battery Replacement, Remove Lithium Coin Battery: шаг 4, изображение 2 из 2
    • Use the spudger, plastic opening tool, or your finger/fingernail to lift up the lithium coin battery.
    • Slide the battery out from underneath the clip that holds it in place.
    • The positive side of the battery is facing up.
Заключение
Katy Beth Culp
Участник с: 10/13/14
1 Репутация
Автор 2 руководств
Команда
Clemson, Team 1-1, Benson Fall 2014 Участник Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 членов
Автор 16 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 14
За всё время: 1,105
