Введение
Electrolytic capacitors are electronic components used to store energy. If too much current runs through a capacitor, it may become bulged and need to be replaced. To replace a capacitor on the MRV-M500 you will need previous experience soldering electronics. To learn how to solder, see this guide.
Запчасти
No parts specified.
Remove all the Phillips 10.0mm and 7.0mm screws on the outside of the case.
Remove all Phillips 7.5mm, 12.5mm, and 10.5mm screws holding the circuit board to the case.
Remove the circuit board from the case.
Find the faulty capacitor.
Flip the board over and locate the corresponding pins.
2 участников успешно повторили данное руководство.
