Введение
If your Altec Lansing Super Life Jacket speaker handle damaged, faculty, or loose, use the following step-by-step guide to replace it.
Выберете то, что вам нужно
Use your hands to remove the pegs (4) located on both sides of the speaker.
Remove the 4 7.8mm Phillips screws on the speaker cover using the PH0 screwdriver.
Carefully slide the handle off the speaker but pushing upwards to the direction the handle is facing.
2 Комментариев
where can i get a battery replacement?
I ordered mine from Amazon.
