Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
If you need access to any of the internal components of your Altec Lansing VersA Smart speaker to replace components, start with this basic removal guide. This guide is a prerequisite to all other repair guides. In this guide, you will remove all external panels and coverings to expose the components within.
  1. Remove external rubber cover.
    • Remove external rubber cover.
  2. Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom. Use a lever motion, push the tool down, lifting the speaker face.
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
  3. Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side. Remove the seven 14mm screws using the Phillips #1 screwdriver.
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
  4. Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
Финишная черта
Rachael Hopp
Участник с: 10.09.2018
517 Репутация
Автор 5 руководств
Команда
University of Alabama, Team S1-G3, Bedsole Fall 2018 Участник University of Alabama, Team S1-G3, Bedsole Fall 2018
UA-BEDSOLE-F18S1G3
3 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 87
