Alternative Opening Procedure
Выберете то, что вам нужно
  1. Alternative Opening Procedure, Alternative Opening Procedure: шаг 1, изображение 1 из 1
    • Instead of a putty knife a dozen or more 1-1/2" pins are required.
  2. Alternative Opening Procedure: шаг 2, изображение 1 из 2 Alternative Opening Procedure: шаг 2, изображение 2 из 2
    • With the computer upside down identify the apertures where the catches are located along either side and also at the front.
    • Insert the pins from the adjacent apertures between the wall and each catch. Be very careful to keep the pins against the case wall. This is more obvious from the second photo with the case removed.
  3. Alternative Opening Procedure: шаг 3, изображение 1 из 1
    • Lift the case off from the back first.
    • Remove the pins from the main assembly.
    I found that I just wedged about eight butter knives around two sides and then to gently press them all at the same time and it kind of popped up.
    Antonella Francesca - Ответить
Заключение
Re-assembly does not require the pins. Place the case over the computer and press down evenly on the sides, not the middle. Ensure the back panel is correctly aligned before finally pushing home the catches.
16 человек успешно провели ремонт по этому руководству.
Donald Todd
Участник с: 09/22/10
528 Репутация
1 руководство автора
1Комментарий к руководству
I've recently acquired a G4 Mini 1.33 "Silent Upgrade" on eBay and plan on opening up using your guide :) Thanks so very, VERY much!
Tyler Regas - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 14
За всё время: 15,243
