Введение
This guide will walk you through how to replace the screen to your digital frame. This is one of the most simplest guides and doesn't take a lot of time at all.
Выберете то, что вам нужно
Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
Pull the ribbon cable away from the motherboard.
Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
