Введение
Here is an Amana washer that had issues with the shift actuator. This was determined after running the automatic diagnostics. Replacement is straight forward with no pitfalls or difficulties.
Выберете то, что вам нужно
To work on this replacement, you will need to gain access to the bottom. It is best to place the washer on its front. Place a few old blankets etc. so as not to scratch the front to much. Since I did a total rebuild on this washer, I had also removed the control panel. It was easier for me to place the washer upside down :-)
First the pulley cover has to be removed. It is attached via two 5/16 bolts
Use an electric screwdriver with a short extension and a 5/16 socket to remove the right screw,
followed by the left screw, is easiest. A hand ratchet or a nut driver will of course work as well.
Remove the pulley cover
Now clearly visible are
The motor
The pulley for the drive (clutch/splutch is underneath)
The shift actuator
The start capacitor for the motor
Here is a close up of the shift actuator
Remove the electrical connector by squeezing the locking tab down and pulling the connector off.
The actuator is held in place by two Philips head screws. Here they are actually using two green colored screws
Use a #2 Philips screwdriver to remove the left
and right screw.
Remove the actuator by pulling it up so that the pin clears the shifter assembly
2 человек успешно провели ремонт по этому руководству.
