Amazon Echo 2nd Generation MIC Board Replacement
Выберете то, что вам нужно
  1. Amazon Echo 2nd Generation MIC Board Replacement, AMP Board: шаг 1, изображение 1 из 3 Amazon Echo 2nd Generation MIC Board Replacement, AMP Board: шаг 1, изображение 2 из 3 Amazon Echo 2nd Generation MIC Board Replacement, AMP Board: шаг 1, изображение 3 из 3
    • Remove the rubber layer beneath the device.
    • Look for the crater beneath the rubber layer and place your thumb on it. Hold down and lift off the cover with your other hand.
    • Remove the four 8.0 mm T8 Torx screws on the lid.
    • Remove the lid from the device.
    Removing the rubber layer does not actually seem to be necessary.
    jrhifixit - Ответить
    Where do you get the replacement Pcb
    niall.mcgee1 - Ответить
    Rubber base removal not necessary.
    Screws for first few steps may be T10, but a quality T8 driver may also work
    Vicente Laluz - Ответить
  2. Amazon Echo 2nd Generation MIC Board Replacement: шаг 2, изображение 1 из 3 Amazon Echo 2nd Generation MIC Board Replacement: шаг 2, изображение 2 из 3 Amazon Echo 2nd Generation MIC Board Replacement: шаг 2, изображение 3 из 3
    • Use a spudger to flip up the small flap on the ZIF connector.
    • Gently pull the ribbon cable out of the ZIF connector.
    • Lift the AMP Board gently while sliding the ribbon cable out through the center hole to reveal another set of wires underneath the board.
    Amp board may have two T10 screws holding tweeter speaker, do not remove.
    Hi please where can find new main board? Thanks.
    Frank Kofi Agyapong - Ответить
    I am from India. If you find pls let me know
    Dhanapal -
    Where can I get new main board in India
    Dhanapal - Ответить
  3. Amazon Echo 2nd Generation MIC Board Replacement: шаг 3, изображение 1 из 2 Amazon Echo 2nd Generation MIC Board Replacement: шаг 3, изображение 2 из 2
    • Use a spudger to lift up one of the small flaps on only one side of the female connector.
    • Pull on the wire toward the lifted side until the male connector is disconnected.
    • Remove the AMP Board.
  4. Amazon Echo 2nd Generation MIC Board Replacement, Subwoofer (speaker): шаг 4, изображение 1 из 2 Amazon Echo 2nd Generation MIC Board Replacement, Subwoofer (speaker): шаг 4, изображение 2 из 2
    • Remove the four 30.0 mm T8 Torx screws in the corners.
    • Remove the large plastic piece on top of the subwoofer while threading the ribbon cable and male connector through the hole.
    These screws are T10, not T8
    Chris D - Ответить
  5. Amazon Echo 2nd Generation MIC Board Replacement: шаг 5, изображение 1 из 2 Amazon Echo 2nd Generation MIC Board Replacement: шаг 5, изображение 2 из 2
    • Remove the lid on top of the subwoofer.
    • Flip the device over and let the subwoofer fall into your hand.
    • The subwoofer is a strong magnet. Keep it away from any other electronics and unshielded wires.
    I found the subwoofer was lightly adhered to the case, and didn’t “fall into” my hand until I very gently separated its edge with the point of a spudger.
    Where can you get the replacement speakers?
    Jeff Emery - Ответить
  6. Amazon Echo 2nd Generation MIC Board Replacement, Front Cover Panel: шаг 6, изображение 1 из 2 Amazon Echo 2nd Generation MIC Board Replacement, Front Cover Panel: шаг 6, изображение 2 из 2
    • Remove the four 16.0 mm T8 Torx screws underneath the speaker.
    • Once you unscrew the four 16.0 mm T8 Torx screws, the remaining components of the device have no support. Take caution when flipping the device over to avoid damage to the remaining components.
    • Flip the device over while supporting the front panel side.
    • Remove the front panel cover by lifting it.
    The front panel cover doesn’t seem to be keyed, so if you find yourself wondering, the “+” button should be positioned to be closest to the power connector (the long plastic strip the slightly moves out of the rest of the cylindrical chassis.
  7. Amazon Echo 2nd Generation MIC Board Replacement, MIC Board: шаг 7, изображение 1 из 3 Amazon Echo 2nd Generation MIC Board Replacement, MIC Board: шаг 7, изображение 2 из 3 Amazon Echo 2nd Generation MIC Board Replacement, MIC Board: шаг 7, изображение 3 из 3
    • Lift the MIC board over and lay it down against a surface.
    • Disconnect the ribbon cable from the MIC board and pull the board away.
    Where can I find the MIC Board replacement?
    Diego Sanjines Flores - Ответить
Заключение
Еще один человек закончил это руководство.
Billy Pho
Участник с: 10/08/18
437 Репутация
Автор 2 руководств
Команда
Cal Poly, Team S4-G4, White Fall 2018 Участник Cal Poly, Team S4-G4, White Fall 2018
CPSU-WHITE-F18S4G4
3 членов
Автор 5 руководств
Один комментарий
Is there a place to buy a replacement MIC Board?
Michael Petrucci - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 2,698
