Введение
Use this guide to replace the 4-in-1 WiFi/Bluetooth/FM/GPS board on the Amazon Echo Dot 2nd generation. The 4-in-1 is located on the motherboard, so the whole board must be replaced, rather than replacing each individual component.
Выберете то, что вам нужно
Power off and unplug the echo
Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
Use a T8 screwdriver bit to unscrew the four 1.6mm torx screws
Remove the black cylindrical base
Use the metal spudger to lift the ZIF connector
Remove the ribbon cable from the slot
8 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
Where can I find the part my dot won’t connect and I have been going crazy trying to find the motherboard
I wish to recommend not removing the adhesive layer if you plan to reassemble this Echo Dot. I would suggest poking holes to reach the four screws instead. Then reassembly can reuse the same adhesive layer.
