Введение
Use this guide to replace the analog to digital convertor on the Amazon Echo Dot. This component is located on the LED/speaker board, however, the whole board must be replaced, rather than just the analog to digital convertor.
Выберете то, что вам нужно
Power off and unplug the echo
Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
Use a T8 screwdriver to unscrew the four 1.6mm torx screws
Remove the black cylindrical base
Use the metal spudger to lift the ZIF connector
Remove the ribbon cable from the slot
Remove the silver divider
Remove the black rubber divider
Remove the plastic white frame
Remove the ribbon cable from the slot on the speaker board
