Введение
Use this guide to replace the LED/speaker and microphone board in the Amazon Echo Dot 2nd generation. Both the LED, speaker, and microphone are located on the same board within the device. The whole board must be replaced, rather than each individual component.
Выберете то, что вам нужно
Power off and unplug the echo
Using the plastic opening tool, peel off the rubber layer on the bottom of the echo.
Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
Remove the black cylindrical base
Use the metal spudger to lift the ZIF connector
Remove the ribbon cable from the slot
Remove the silver divider
Remove black rubber divider
Remove the plastic white frame
Remove the ribbon cable from the slot on the LED/speaker board
4 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
I can’t seem to find the board anywhere. Where would you buy one?
