Введение
Use this guide to replace the ribbon cable in the Amazon Echo Dot 2nd Generation.
Выберете то, что вам нужно
Power off and unplug the echo
Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
Use a T8 screwdriver bit to unscrew the 1.6mm four screws.
Remove the black cylindrical base
Use the metal spudger to lift the ZIF connector
Remove the ribbon cable from the slot
Remove the silver divider
Remove the black rubber divider
Remove the plastic white frame
Remove the ribbon cable from the slot on the LED/speaker board
4 участников успешно повторили данное руководство.
5 Комментариев
Where do you get the replacement cable from?
Yes, where can one get replacement ribbon cables?
I need a replacement as well now was using a pointed tweezers when putting it back together and stabbed the cable need to find part and order from the uk
no cable available, just waiting for donors
