Введение
If necessary, removing the CPU PCB allows for a complete reset of your Amazon Echo's memory. It is easy to remove and is the first step in disassembling the rest of the device.
After removing a few screws and the ribbon cable, a new CPU PCB can be inserted. Removing it only requires a spudger for the backing and a thin prying tool for disconnecting the ribbon cable.
Выберете то, что вам нужно
Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
