Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide shows how to replace the power and speaker driver board in the Amazon Echo. This board is responsible for delivering power to the various components of the Echo and also delivers the appropriate signals to the woofer and tweeter. This guide may prove helpful if your Echo has issues turning on, sounds distorted, or won't make any sound.
Выберете то, что вам нужно
Peel off the rubber footing from the bottom of the Echo.
Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
Using the spudger, pull back the two plastic clips on the plate.
Lift the board up and pull it away from the plate.
10 участников успешно повторили данное руководство.
22 Комментариев
It's great that you have provided these instructions. I need to do this with mine. Do you know where I can get a replacement board?
Taylor, did you ever find a new board? I need one too.
Great instructions BUT ...... THERE IS NO PLACE TO BUY THE BOARD!! (It's proprietary to Amazon) So this instruction is about as useful as jumping out of a plane before asking for a parachute.
Where do I get a replacement board ?
