Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
Using the spudger, pull back the two plastic clips on the plate.
Lift the board up and pull it away from the plate.
10 участников успешно повторили данное руководство.
22 Комментариев
It's great that you have provided these instructions. I need to do this with mine. Do you know where I can get a replacement board?
Taylor, did you ever find a new board? I need one too.
Great instructions BUT ...... THERE IS NO PLACE TO BUY THE BOARD!! (It's proprietary to Amazon) So this instruction is about as useful as jumping out of a plane before asking for a parachute.
Where do I get a replacement board ?
