Выберете то, что вам нужно
Remove the four white stickers on your device's back panel.
Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
Unscrew the four 50 mm screws with a T3 Torx screwdriver.
Pop the sides and remove the back panel of the device.
Remove the five 2 mm screws with a Torx T5 screwdriver.
Remove the two 5 mm with a Torx T3 screwdriver.
Remove both ends of the connector from the main device.
Remove the black panel.
