Введение
If your Amazon Echo Show 15 (model H6Y2A5) is plagued by software malfunctions or features a non-functional motherboard, use this guide for comprehensive motherboard replacement.
The motherboard plays a critical role in the overall functionality of the Echo Show 15, and addressing software issues may necessitate a replacement.
Before starting the motherboard replacement, ensure your device is powered off completely and disconnected from any external power sources. This guide provides step-by-step instructions on how to replace the motherboard, allowing you to restore your Amazon Echo Show 15 to optimal performance.
Выберете то, что вам нужно
Remove the four white stickers on your device's back panel.
Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
Unscrew the four 50 mm screws with a T3 Torx screwdriver.
Pop the sides and remove the back panel of the device.
Remove the five 3 mm screws from the metal protector using a Torx T5 screwdriver.
Take off the metal protector.
Remove the twelve 3 mm screws from the motherboard using the Torx T5 screwdriver.
Detach the connectors for the camera and buttons from the motherboard.
Detach the connectors for the power station and speakers from the motherboard.
Detach the small white coaxial cables from the motherboard.
