Введение
If your Amazon Echo Show 15 (model H6Y2A5) is producing distorted audio, experiencing sudden sound loss, or displaying physical damage to the speakers, use this guide for speaker replacement.
The speakers are integral to the Echo Show 15's audio output, and issues with distorted or lost sound can significantly impact the device's functionality.
Before commencing the speaker replacement, ensure your device is powered off completely and disconnected from any external power sources. This guide offers step-by-step instructions on how to replace the speakers, allowing you to restore optimal audio quality to your Amazon Echo Show 15.
Выберете то, что вам нужно
Remove the four white stickers on your device's back panel.
Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
Unscrew the four 50 mm screws with a T3 Torx screwdriver.
Pop the sides and remove the back panel of the device.
Remove the five 2 mm screws per speaker (ten total) with a Torx T5 screwdriver.
Locate the motherboard and the cables connected to the speakers.
Remove the orange sticker on top of the cord using a pair of tweezers.
Unplug the cable by pulling it towards you.
Еще один человек закончил это руководство.
