Введение
If your Amazon Echo Show's audio is crackly or muffled, you might need to replace the speakers. Follow the prerequisite guide listed at the top--"Opening The Show". This guide tells you how to open up the device so you can access the speakers.
Before starting this guide, gather a T4, T5, and T6 Torx screwdriver. Steps requiring a tweezer can instead be used with your hands carefully.
Выберете то, что вам нужно
Using your hands, gently remove the taped-in rubber foot from device.
Carefully peel off the bottom pad to expose the fastening screws.
Remove three silver 1.4 T5 Torx screws on the top row.
Remove one green 1mm T5 Torx screw in the middle.
Remove a black 1.5mm T5 screw.
Remove three green 1mm T5 screws from the bottom row.
After the screws are removed, grip the front panel and remove, using a plastic opening tool if necessary. This will expose the inside of the device.
Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
Repeat this step for the other speaker, and lay the front section flat with the facing down.
Use a non-magnetic T-6 screwdriver to unscrew the four 6mm screws on the speaker mount.
Repeat this step for the other speaker.
3 участников успешно повторили данное руководство.
2 Комментариев
Seems you missed an important step on here. How do you get the front off the box? Show how to remove the speaker grill, the grill cloth and then pry up the digitizer and screen. That’s where all the f***ing screws are!!! That’s how you get into this damned thing!! But you left all that ‘unimportant’ stuff out.
Where do you get a replacement speakers
