Введение
This guide demonstrates how to replace the tweeter assembly in the Amazon Echo. Removing the assembly is a prerequisite for replacing the tweeter or woofer.
Запчасти
No parts specified.
  1. Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo. Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo. Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Apple Watch Kits
    Screen and battery repairs just got easier.
    Купить сейчас
    Apple Watch Kits
    Купить сейчас
  5. Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
    Könnt ihr Ersatzteil machen für Amazon Echo
    Okka Mehmed - Ответить
    Wo kann ich Ersatzteile holen für Amazon Echo
  6. Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable. Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
    Were do you get the board?
    nick poverman - Ответить
  7. Using the spudger, pull back the two plastic clips on the plate. Lift the board up and pull it away from the plate. Lift the board up and pull it away from the plate.
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
    I need to find a replacement board. Where can I find one?
    Matthew Webster - Ответить
    Me to, i need this board to my alexa echo
    benjaminaflorentino - Ответить
    So anyone found out where we can get these boards and other components ?
    Jimmy - Ответить
  8. Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding. Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  9. Peel off the black fabric wrapped around the Echo.
    • Peel off the black fabric wrapped around the Echo.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  10. Remove the four 42.8 mm T10 Torx screws around the tweeter. Lift the tweeter and its attached housing from the device. Lift the tweeter and its attached housing from the device.
    • Remove the four 42.8 mm T10 Torx screws around the tweeter.
    • Lift the tweeter and its attached housing from the device.
Заключение
Alexander Albert
Участник с: 04.02.2016
1 028 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 3-3, Wollert Spring 2016 Member of USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 членов
Автор 12 руководств
Комментариев: 3
I've gotten this far, but where do you get a replacement? No brand or model # on tweeter.
Kyle - Ответить
Are you saying removing it and replacing the same tweeter is what you have to do? It says no parts.
kathy1557 - Ответить
The primary purpose of this guide is to show you how to remove a failing tweeter so that you can replace it with a new one. The "no parts required" text appears at the top of this guide because the author didn't have a source for the replacement part.
Ron Davis -
Добавить комментарий
Просмотр статистики:
За 24 часа: 2
За 7 дней: 4
За 30 дней: 23
За всё время: 2,271
