Введение
This guide will show you how to replace the woofer, the speaker in the Amazon Echo responsible for the low-frequency bass. This guide should be helpful if your Echo is lacking bass or sounds otherwise distorted.
Выберете то, что вам нужно
Peel off the rubber footing from the bottom of the Echo.
Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
Könnt ihr Ersatzteil machen für Amazon Echo
Wo kann ich Ersatzteile holen für Amazon Echo
Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
Using the spudger, pull back the two plastic clips on the plate.
Lift the board up and pull it away from the plate.
I need to find a replacement board. Where can I find one?
Me to, i need this board to my alexa echo
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
Remove the four 42.8 mm T10 Torx screws around the tweeter.
Lift the tweeter and its attached housing from the device.
Еще один человек закончил это руководство.
3 Комментариев
Where can you buy a replacement woofer?
My exact question.
