Amazon Fire HD 10 Screen Replacement
Выберете то, что вам нужно
  1. Amazon Fire HD 10 Screen Replacement, Screen: шаг 1, изображение 1 из 3 Amazon Fire HD 10 Screen Replacement, Screen: шаг 1, изображение 2 из 3 Amazon Fire HD 10 Screen Replacement, Screen: шаг 1, изображение 3 из 3
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Screen Replacement: шаг 2, изображение 1 из 1
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Screen Replacement: шаг 3, изображение 1 из 2 Amazon Fire HD 10 Screen Replacement: шаг 3, изображение 2 из 2
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Screen Replacement: шаг 4, изображение 1 из 1
    • Remove the screen and digitizer from the case completely.
Заключение
26 участников успешно повторили данное руководство.
Jaie Hillery
Участник с: 10/07/14
1 718 Репутация
Автор 10 руководств
Команда
USF Tampa, Team 16-6, Blackwell Winter 2016 Участник USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 членов
Автор 22 руководств
16 Комментариев
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - Ответить
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland -
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - Ответить
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - Ответить
What is needed to attach the screen back to the case?
Jimmy Lee - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 42
За последние 30 дней: 159
За всё время: 34,869
