Введение
This device has a 2 megapixel Rear-facing camera and this guide will help you locate and replace this part.
Выберете то, что вам нужно
Insert the plastic opening tool behind the rear case to free the clips holding the case together.
Work your way around the device to free all the clips.
There are an additional nine clips surrounding the battery area. Place the plastic tool into the clips and lift to disconnect them.
Once all clips have been released, the back case can be pulled free to reveal the inside of the device.
Unscrew the two screws using a T5 screwdriver.
Once freed from the screws, gently lift and remove the camera.
