Amazon Fire HD 8 12th Gen Speakers Replacement
Выберете то, что вам нужно
  1. Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
    Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: шаг 1, изображение 1 из 3 Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: шаг 1, изображение 2 из 3 Amazon Fire HD 8 12th Gen Speakers Replacement, Buttons: шаг 1, изображение 3 из 3
    • Remove the device from any electrical source and make sure it is powered off.
    • Put picks around the corner and move them along the edge to pry the case off.
    • Once there is separation between the case and the screen, place a pick in between the screen and on the corner of the back case.
  2. Amazon Fire HD 8 12th Gen Speakers Replacement: шаг 2, изображение 1 из 2 Amazon Fire HD 8 12th Gen Speakers Replacement: шаг 2, изображение 2 из 2
    • With the corners lifted, take the opening tool and pry each corner off.
    • Repeat this for the corner diagonal from the initial corner.
    • Once both corners are pried off, gently take the back case off the device.
  3. Amazon Fire HD 8 12th Gen Speakers Replacement, Speakers: шаг 3, изображение 1 из 1
    • Disconnect the red and black wires connected to the motherboard.
  4. Amazon Fire HD 8 12th Gen Speakers Replacement: шаг 4, изображение 1 из 3 Amazon Fire HD 8 12th Gen Speakers Replacement: шаг 4, изображение 2 из 3 Amazon Fire HD 8 12th Gen Speakers Replacement: шаг 4, изображение 3 из 3
    • Heat glue up to loosen the black and red wires, then lift and remove black and red wires.
    • Be careful of hot metals/parts and hot tools.
  5. Amazon Fire HD 8 12th Gen Speakers Replacement: шаг 5, изображение 1 из 3 Amazon Fire HD 8 12th Gen Speakers Replacement: шаг 5, изображение 2 из 3 Amazon Fire HD 8 12th Gen Speakers Replacement: шаг 5, изображение 3 из 3
    • Get metal speaker parts hot as well and lift the metal speaker up.
    • Do this for the other set of speakers and repeat the steps again.
    • Be careful of hot tools and hot parts.
Заключение
Jaden Palmer
Участник с: 09/06/23
485 Репутация
Автор 4 руководств
Команда
University of Memphis, Team 1-1, Sneed Fall 2023 Участник University of Memphis, Team 1-1, Sneed Fall 2023
UM-SNEED-F23S1G1
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 82
