Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
Pop the camera out of the rear-facing camera casing by carefully pulling the orange cable with the tweezers.
Flip up the tab on the ZIF connector at the end of the ribbon cable.
Grasp the underside of the orange cable with the tweezers and gently slide the camera out of the connector.
2 участников успешно повторили данное руководство.
